M
MediaCodec problem
Guest
Cross post: http://stackoverflow.com/questions/34143942/android-enconding-audio-and-video-using-mediacodec
I'm trying to encode video from camera and audio from microphone using MediaCodec and MediaMuxer. I use OpenGL to overlay text on the image while recording.
I took these classes as example:
I wrote a main class that performs the encoding. It spawns 2 threads for recording audio and video. It does not work (the generated file is not valid), but if I comment one of the threads (either audio or video), it works ok. Also, I need to set TRACK_COUNT to 1. This is the code for the main class:
import android.graphics.SurfaceTexture;
import android.media.AudioFormat;
import android.media.AudioRecord;
import android.media.MediaCodec;
import android.media.MediaCodecInfo;
import android.media.MediaFormat;
import android.media.MediaMuxer;
import android.media.MediaRecorder;
import com.google.common.base.Throwables;
import java.io.IOException;
import java.nio.ByteBuffer;
import static com.google.common.base.Preconditions.checkNotNull;
* Class for recording a reply including a text message.
public class ReplyRecorder {
// Encoding state
private boolean encoding;
long startWhen;
// Muxer
private static final int TRACK_COUNT = 2;
private Muxer mMuxer;
// Video
private static final String VIDEO_MIME_TYPE = "video/avc"; // H.264 Advanced Video Coding
private static final int FRAME_RATE = 15; // 30fps
private static final int IFRAME_INTERVAL = 10; // 5 seconds between I-frames
private static final int BIT_RATE = 2000000;
private Encoder mVideoEncoder;
private CodecInputSurface mInputSurface;
private SurfaceTextureManager mStManager;
// Audio
private static final String AUDIO_MIME_TYPE = "audio/mp4a-latm";
private static final int SAMPLE_RATE = 44100;
private static final int SAMPLES_PER_FRAME = 1024;
private static final int CHANNEL_CONFIG = AudioFormat.CHANNEL_IN_MONO;
private static final int AUDIO_FORMAT = AudioFormat.ENCODING_PCM_16BIT;
private Encoder mAudioEncoder;
private AudioRecord audioRecord;
public void start(final CameraManager cameraManager, final String messageText, final String filePath) {
checkNotNull(cameraManager);
checkNotNull(messageText);
checkNotNull(filePath);
try {
// Create a MediaMuxer. We can't add the video track and start() the muxer here,
// because our MediaFormat doesn't have the Magic Goodies. These can only be
// obtained from the encoder after it has started processing data.
mMuxer = new Muxer(new MediaMuxer(filePath, MediaMuxer.OutputFormat.MUXER_OUTPUT_MPEG_4), TRACK_COUNT);
startWhen = System.nanoTime();
encoding = true;
new Thread(new Runnable() {
@override
public void run() {
initVideoComponents(cameraManager, messageText);
encodeVideo(cameraManager);
}).start();
@override
public void run() {
initAudioComponents();
encodeAudio();
}).start();
} catch (IOException e) {
release();
throw Throwables.propagate(e);
private void initVideoComponents(CameraManager cameraManager,
String messageText) {
try {
MediaFormat format = MediaFormat.createVideoFormat(VIDEO_MIME_TYPE, cameraManager.getEncWidth(), cameraManager.getEncHeight());
// Set some properties. Failing to specify some of these can cause the MediaCodec
// configure() call to throw an unhelpful exception.
format.setInteger(MediaFormat.KEY_COLOR_FORMAT,
MediaCodecInfo.CodecCapabilities.COLOR_FormatSurface);
format.setInteger(MediaFormat.KEY_BIT_RATE, BIT_RATE);
format.setInteger(MediaFormat.KEY_FRAME_RATE, FRAME_RATE);
format.setInteger(MediaFormat.KEY_I_FRAME_INTERVAL, IFRAME_INTERVAL);
// Create a MediaCodec encoder, and configure it with our format. Get a Surface
// we can use for input and wrap it with a class that handles the EGL work.
// If you want to have two EGL contexts -- one for display, one for recording --
// you will likely want to defer instantiation of CodecInputSurface until after the
// "display" EGL context is created, then modify the eglCreateContext call to
// take eglGetCurrentContext() as the share_context argument.
mVideoEncoder = new Encoder(VIDEO_MIME_TYPE, format, mMuxer);
mInputSurface = new CodecInputSurface(mVideoEncoder.getEncoder().createInputSurface());
mVideoEncoder.getEncoder().start();
mInputSurface.makeCurrent();
mStManager = new SurfaceTextureManager(messageText, cameraManager.getEncWidth(), cameraManager.getEncHeight());
} catch (RuntimeException e) {
releaseVideo();
throw e;
private void encodeVideo(CameraManager cameraManager) {
try {
SurfaceTexture st = mStManager.getSurfaceTexture();
cameraManager.record(st);
while (encoding) {
// Feed any pending encoder output into the muxer.
mVideoEncoder.drain(false);
// Acquire a new frame of input, and render it to the Surface. If we had a
// GLSurfaceView we could switch EGL contexts and call drawImage() a second
// time to render it on screen. The texture can be shared between contexts by
// passing the GLSurfaceView's EGLContext as eglCreateContext()'s share_context
// argument.
mStManager.awaitNewImage();
mStManager.drawImage();
// Set the presentation time stamp from the SurfaceTexture's time stamp. This
// will be used by MediaMuxer to set the PTS in the video.
mInputSurface.setPresentationTime(st.getTimestamp() - startWhen);
// Submit it to the encoder. The eglSwapBuffers call will block if the input
// is full, which would be bad if it stayed full until we dequeued an output
// buffer (which we can't do, since we're stuck here). So long as we fully drain
// the encoder before supplying additional input, the system guarantees that we
// can supply another frame without blocking.
mInputSurface.swapBuffers();
// send end-of-stream to encoder, and drain remaining output
mVideoEncoder.drain(true);
} finally {
releaseVideo();
private void initAudioComponents() {
try {
int min_buffer_size = AudioRecord.getMinBufferSize(SAMPLE_RATE, CHANNEL_CONFIG, AUDIO_FORMAT);
int buffer_size = SAMPLES_PER_FRAME * 10;
if (buffer_size < min_buffer_size)
buffer_size = ((min_buffer_size / SAMPLES_PER_FRAME) + 1) * SAMPLES_PER_FRAME * 2;
audioRecord = new AudioRecord(
MediaRecorder.AudioSource.MIC, // source
SAMPLE_RATE, // sample rate, hz
CHANNEL_CONFIG, // channels
AUDIO_FORMAT, // audio format
buffer_size); // buffer size (bytes)
MediaFormat format = new MediaFormat();
format.setString(MediaFormat.KEY_MIME, AUDIO_MIME_TYPE);
format.setInteger(MediaFormat.KEY_AAC_PROFILE, MediaCodecInfo.CodecProfileLevel.AACObjectLC);
format.setInteger(MediaFormat.KEY_SAMPLE_RATE, 44100);
format.setInteger(MediaFormat.KEY_CHANNEL_COUNT, 1);
format.setInteger(MediaFormat.KEY_BIT_RATE, 128000);
format.setInteger(MediaFormat.KEY_MAX_INPUT_SIZE, 16384);
mAudioEncoder = new Encoder(AUDIO_MIME_TYPE, format, mMuxer);
mAudioEncoder.getEncoder().start();
releaseAudio();
throw e;
private void encodeAudio() {
try {
audioRecord.startRecording();
while (encoding) {
mAudioEncoder.drain(false);
sendAudioToEncoder(false);
//TODO: Sending "false" because calling signalEndOfInputStream fails on this encoder
} finally {
releaseAudio();
public void sendAudioToEncoder(boolean endOfStream) {
// send current frame data to encoder
ByteBuffer[] inputBuffers = mAudioEncoder.getEncoder().getInputBuffers();
int inputBufferIndex = mAudioEncoder.getEncoder().dequeueInputBuffer(-1);
if (inputBufferIndex >= 0) {
ByteBuffer inputBuffer = inputBuffers[inputBufferIndex];
inputBuffer.clear();
long presentationTimeNs = System.nanoTime();
int inputLength = audioRecord.read(inputBuffer, SAMPLES_PER_FRAME);
presentationTimeNs -= (inputLength / SAMPLE_RATE) / 1000000000;
long presentationTimeUs = (presentationTimeNs - startWhen) / 1000;
if (endOfStream) {
mAudioEncoder.getEncoder().queueInputBuffer(inputBufferIndex, 0, inputLength, presentationTimeUs, MediaCodec.BUFFER_FLAG_END_OF_STREAM);
} else {
mAudioEncoder.getEncoder().queueInputBuffer(inputBufferIndex, 0, inputLength, presentationTimeUs, 0);
public void stop() {
encoding = false;
* Releases encoder resources.
public void release() {
releaseVideo();
releaseAudio();
private void releaseVideo() {
if (mVideoEncoder != null) {
mVideoEncoder.release();
mVideoEncoder = null;
if (mInputSurface != null) {
mInputSurface.release();
mInputSurface = null;
if (mStManager != null) {
mStManager.release();
mStManager = null;
releaseMuxer();
private void releaseAudio() {
if (audioRecord != null) {
audioRecord.stop();
audioRecord = null;
if (mAudioEncoder != null) {
mAudioEncoder.release();
mAudioEncoder = null;
releaseMuxer();
private void releaseMuxer() {
if (mMuxer != null && mVideoEncoder == null && mAudioEncoder == null) {
mMuxer.release();
mMuxer = null;
public boolean isRecording() {
return mMuxer != null;
The class that wraps the muxer and waits for tracks to be completed before starting is the following (I added some synchronized just to test):
import static com.google.common.base.Preconditions.checkState;
* Class responsible for muxing. Wraps a MediaMuxer.
public class Muxer {
private final MediaMuxer muxer;
private final int totalTracks;
private int trackCounter;
public Muxer(MediaMuxer muxer, int totalTracks) {
this.muxer = checkNotNull(muxer);
this.totalTracks = totalTracks;
synchronized public int addTrack(MediaFormat format) {
checkState(!isStarted(), "Muxer already started");
int trackIndex = muxer.addTrack(format);
trackCounter++;
if (isStarted()) {
muxer.start();
notifyAll();
} else {
while (!isStarted()) {
try {
wait();
} catch (InterruptedException e) {
return trackIndex;
synchronized public void writeSampleData(int trackIndex, ByteBuffer byteBuf,
MediaCodec.BufferInfo bufferInfo) {
checkState(isStarted(), "Muxer not started");
muxer.writeSampleData(trackIndex, byteBuf, bufferInfo);
if (muxer != null) {
try {
muxer.stop();
} catch (Exception e) {
muxer.release();
private boolean isStarted() {
return trackCounter == totalTracks;
And the class responsible for writing to MediaCodec encoder is the following:
* Class responsible for encoding.
public class Encoder {
private final MediaCodec encoder;
private final Muxer muxer;
private final MediaCodec.BufferInfo bufferInfo;
private int trackIndex;
public Encoder(String mimeType, MediaFormat format, Muxer muxer) {
checkNotNull(mimeType);
checkNotNull(format);
try {
encoder = MediaCodec.createEncoderByType(mimeType);
encoder.configure(format, null, null, MediaCodec.CONFIGURE_FLAG_ENCODE);
this.muxer = muxer;
bufferInfo = new MediaCodec.BufferInfo();
public MediaCodec getEncoder() {
return encoder;
* Extracts all pending data from the encoder and forwards it to the muxer.
* <p/>
* If endOfStream is not set, this returns when there is no more data to drain. If it
* is set, we send EOS to the encoder, and then iterate until we see EOS on the output.
* Calling this with endOfStream set should be done once, right before stopping the muxer.
* <p/>
* We're just using the muxer to get a .mp4 file (instead of a raw H.264 stream).
public void drain(boolean endOfStream) {
final int TIMEOUT_USEC = 10000;
if (endOfStream) {
encoder.signalEndOfInputStream();
ByteBuffer[] encoderOutputBuffers = encoder.getOutputBuffers();
while (true) {
int encoderStatus = encoder.dequeueOutputBuffer(bufferInfo, TIMEOUT_USEC);
if (encoderStatus == MediaCodec.INFO_TRY_AGAIN_LATER) {
// no output available yet
if (!endOfStream) {
break; // out of while
} else if (encoderStatus == MediaCodec.INFO_OUTPUT_BUFFERS_CHANGED) {
// not expected for an encoder
} else if (encoderStatus == MediaCodec.INFO_OUTPUT_FORMAT_CHANGED) {
// now that we have the Magic Goodies, start the muxer
trackIndex = muxer.addTrack(encoder.getOutputFormat());
} else if (encoderStatus < 0) {
// let's ignore it
} else {
ByteBuffer encodedData = encoderOutputBuffers[encoderStatus];
checkState(encodedData != null, "encoderOutputBuffer %s was null", encoderStatus);
if ((bufferInfo.flags & MediaCodec.BUFFER_FLAG_CODEC_CONFIG) != 0) {
// The codec config data was pulled out and fed to the muxer when we got
// the INFO_OUTPUT_FORMAT_CHANGED status. Ignore it.
bufferInfo.size = 0;
if (bufferInfo.size != 0) {
// adjust the ByteBuffer values to match BufferInfo (not needed?)
encodedData.position(bufferInfo.offset);
encodedData.limit(bufferInfo.offset + bufferInfo.size);
muxer.writeSampleData(trackIndex, encodedData, bufferInfo);
encoder.releaseOutputBuffer(encoderStatus, false);
if ((bufferInfo.flags & MediaCodec.BUFFER_FLAG_END_OF_STREAM) != 0) {
if (encoder != null) {
try {
encoder.stop();
encoder.release();
Any idea why it could be failing when running concurrently?
Thanks in advance.
- http://bigflake.com/mediacodec/CameraToMpegTest.java.txt
- https://github.com/OnlyInAmerica/HW...h/hwencoderexperiments/ChunkedHWRecorder.java
// Encoding state
long startWhen;
// Muxer
// Video
// Audio
try {
encoding = true;
@override
public void run() {
}).start();
@override
public void run() {
encodeAudio();
}).start();
release();
try {
releaseVideo();
throw e;
try {
while (encoding) {
// argument.
} finally {
releaseVideo();
try {
releaseAudio();
throw e;
try {
while (encoding) {
} finally {
releaseAudio();
if (endOfStream) {
} else {
encoding = false;
releaseVideo();
releaseAudio();
mStManager = null;
releaseMuxer();
audioRecord.stop();
audioRecord = null;
releaseMuxer();
mMuxer.release();
mMuxer = null;
trackCounter++;
if (isStarted()) {
muxer.start();
notifyAll();
} else {
try {
wait();
return trackIndex;
try {
muxer.stop();
muxer.release();
try {
this.muxer = muxer;
return encoder;
* <p/>
* <p/>
if (endOfStream) {
while (true) {
if (!endOfStream) {
// let's ignore it
} else {
try {
encoder.stop();
encoder.release();
Thanks in advance.
