problem with contacts
Hello and welcome to Android Forums! :)
It would really be helpful if we know the model of phone and the version of Android you have. Generally, if a cold reset (power off and power back on) doesn't clear up the problem, you might need to perform a factory reset.
My contacts app won't work, when I go to open my contacts, or add a contact, and the screen just goes black.
Hello, you can try to use application GO Contacts Ex, but you must install GO Launcher Ex too. Or you can download application Contacts Backup.
