Root Problem with CWM 5.0.2.6, help!!
This shouldn't be happening man....you did everything by the guide.
Tell you what, leave the rom for now. Go for a fresh Odin install. Get a fresh samsung firmware from sammobile.com, according to your region, a cooper.ops(s5830), Odin software file and the flash guide.
Flash the stock rom and your phone will be brand new. Like it came in the box.
Unrooted, fresh and no CWM, all stock samsung stuff.
where can I download Odin? does it support Mac?
I'm in sammobile page and searched firmwares for my phone model Galaxy Ace GT-S5830,OS:Android,Country:Nordic Countries and type: Smartphone
Now there are 'Additional File'
Type: Drivers, Flashguide, Flashprograms, Flashprograms and Service Manuals so which one I download?
You will need drivers, if you have Kies installed then the drivers are already there, non need to get them again.
Get a flashguide, it will tell you how to use Odin...
Flashprogram, thats only Odin, get the one for S5830,
Firmware, whichever is the latest for your region/carrier, download that.
Ok, but I got only two problems Kies for Mac doesn't support Galaxy Ace and I tried to find odin for Mac one was for s5830i like u told and I need to download other Odin from Piratebay which is impossible because u cant use Piratebay anymore in Finland because operatos had to deny customers access to site. So I need to find Odin for my ace and drivers, right?
Try to get access to a windows machine for just 5 minutes, that'll make things easier. It just takes 5 minutes for Odin to flash a firmware. And you can get the drivers and Odin from sammobile.
I don't know if there is an Odin for mac, never heard anyone using it on mac.
