markdoc
Android Expert
Lately (prior to Lollipop) I have had a problem with ES File Explorer (ES). I can move mp3 sound files in and out of my "Alarms" folders. The issue is when I move them in, they do not appear in any selection list on my phone. This includes my phones "Settings" and all apps. When I move the same files with other file explorers, they show up as expected. I wrote ES support 5 times and their last answer to creating new alarms was,
"Hi. If you want to add new ringtones,you should:
1.Root your device 2.Mount /system path as RW 3.put music files into /system/media/audio/alarms/"
Obviously, not a reasonable answer. The others were just as bad. If anyone else has/doesn't have the same problem, please let me know. A fix would be great too, but I believe it's in the programming.
TIA
TIA
