Help Problem with G1
Recently I have been having problems with my G1, firstly I constantly recieve force close message in the Market when searching for anything. On occasions this happens every 2 searches I do.
Also every so often the phone refuses to boot up sticking on the opening android screen, the animation stops for a second after 30 secs or so then the screen goes blank and the android boot screen returns. I find that I am havin to hard reset every couple of weeks.
Anyone have any ideas as to what is happening here.
I would have suggested a Soft Reset With phone On an stable pull battery and SIM wait 3 or 4 minutes and reinstall )
But, failing that I would have said then try the Factory Reset ,, but you say you have tried that ... so not sure what to suggest ... after Factory Reset .. be careful of the apps you reload taking the time to try them for a bit to see if it force closes .... Also look and see if when the Force Close occurs if it does name the program or process that is failing ...this may be a clue to the offending app...
