Help problem with galaxy captivate(Emergency calls)
GalAxya
hi;;
i have Galaxy Captivata at&t
but only Emergency calls
(Date network not available))
Model number
GT-I9000
Firmware version
2.2
Baseband
I9000jxjpE
kernel
2.6.32.9
build number
froyo.jpjpG
hi;;
Model number
GT-I9000
Firmware version
2.2
Baseband
I9000jxjpE
kernel
2.6.32.9
build number
froyo.jpjpG
Odd, the model number for an AT&T cappy SGH-I897 the samsung vibrant is GT-I9000. Also Froyo 2.2 build number shpuld be FROYO.UCKB1. Kernal is right though. Also your baseband should be I897uckb1.
It appears like you are trying to run Vibrant on the Captivate. I would recomend to use Odin to flash back to 2.1 and then Keis to go to 2.2. That may solve your problem.
[STOCK ROM] Odin3 One-Click Downloader and Drivers CAPTIVATE ONLY - xda-developers
Geeve
thanks alot geeve ,it's working :D:D:D:D:):),
i really appreciate it
model number
Samsung-sgh-i897
firmware version
2.1 update1
baseband version
2.6.29
can i update my phone by going to the settings & software update ????
:) there's another thing i wanna switch the language to arabic
DO YOU KNOW HOW??
No problem! Not sure on the language I would have to look it up. As far as going to 2.2, you need to download the Keis program from Samsung and the drivers as well. Once it is installed just open Keis and connect your phone. One of the USB options on the phone that will appear will be for Keis. Once that is selected Keis will show the update available and you click go. Just like that :)
Geeve
hi
i have sgs i 9000t.
i have emergency call problem like this freind.
i cant solve this with install any 3files rom.
Baseband:i9000xwjw1
frimware version:2.3.6
kernel version: 2.6.35.7-i9000xwjw8-CL1152999
dpi@DELL170#2
build Number:xwjw8
I realy cofused Now.
Anybody can help me?
plzzzzzzzzzzzzzz
