I used to be able to download apps to my phone from my PC. I changed my Google password and now I can't go that any more. Is there a way to update the password on the play store on the phone?
I wouldve thought that it'd update automatically...
Try going through settings > accounts > google > (your account) > *menu* sync now
Not sure if this would work but it's worth a try. You could also try uninstalling the updates for GPlay Store and see if that will help when it autoupdates to the latest version.
(Not exactly root related (at least to me) so I've moved this into the general section for you )
Just go to settings > accounts and remove your current google account. Then add the account again and when asked for your credentials (email address and password) just enter what it is now; everything like contacts, emails and so on will be auto-synced back to your device, including any apps that have been updated since the last time you had access to Play Store.
