Problem with HTC
estepona
My phone shows a message which says
No SIM card. Emergency calls only
Have done nothing untoward and need to fix it. Help please!
Welcome to the forums estepona, depending on the HTC you have, turn your phone off, you should be able to take the back off and remove the sim card and then put it back in and then reboot the phone. Hope that helps.......
