Hello all!
I have a problem with display img + text on listview. I have a code that works ok on simulator but when I install my code on my samsung galaxy s I cant see the pic near the text.
I don't know what the problem because on my simulator its work fine.
Maybe because I don't have an sd card? how can I change my code that it will work ok on my device?
the code is:
on getView
imageLoader.displayImage(imgUrl, activity, ImageView);
thanks for helping
the code is:
on getView
Code:
package rusNewsTest;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileNotFoundException;
import java.io.FileOutputStream;
import java.io.InputStream;
import java.io.OutputStream;
import java.net.URL;
import java.util.HashMap;
import java.util.Stack;
import com.example.News.R;
import android.app.Activity;
import android.content.Context;
import android.graphics.Bitmap;
import android.graphics.BitmapFactory;
import android.widget.ImageView;
public class ImageThreadLoader {
//the simplest in-memory cache implementation. This should be replaced with something like SoftReference or BitmapOptions.inPurgeable(since 1.6)
/** The cache. */
private HashMap<String, Bitmap> cache=new HashMap<String, Bitmap>();
/** The cache dir. */
private File cacheDir;
* Instantiates a new image loader.
* @param context the context
public ImageThreadLoader(Context context){
//Make the background thead low priority. This way it will not affect the UI performance
photoLoaderThread.setPriority(Thread.NORM_PRIORITY-1);
//Find the dir to save cached images
if (android.os.Environment.getExternalStorageState().equals(android.os.Environment.MEDIA_MOUNTED))
cacheDir=new File(android.os.Environment.getExternalStorageDirectory(),"cache_dir_img");
else
cacheDir=context.getCacheDir();
if(!cacheDir.exists())
cacheDir.mkdirs();
//This is used for a stub when the user can not see the actual image..
//this images will be seen
final int stub_id =R.drawable.stub;
* Display image.
* @param url the url
* @param activity the activity
* @param imageView the image view
public void displayImage(String url, Activity activity, ImageView imageView)
if(cache.containsKey(url))
imageView.setImageBitmap(cache.get(url));
else
queuePhoto(url, activity, imageView);
imageView.setImageResource(stub_id);
* Queue photo.
private void queuePhoto(String url, Activity activity, ImageView imageView)
//This ImageView may be used for other images before. So there may be some old tasks in the queue. We need to discard them.
photosQueue.Clean(imageView);
PhotoToLoad p=new PhotoToLoad(url, imageView);
synchronized(photosQueue.photosToLoad){
photosQueue.photosToLoad.push(p);
photosQueue.photosToLoad.notifyAll();
//start thread if it's not started yet
if(photoLoaderThread.getState()==Thread.State.NEW)
photoLoaderThread.start();
* Gets the bitmap.
* @return the bitmap
private Bitmap getBitmap(String url)
//I identify images by hashcode. Not a perfect solution, good for the demo.
String filename=String.valueOf(url.hashCode());
File f=new File(cacheDir, filename);
//from SD cache
Bitmap b = decodeFile(f);
if(b!=null)
return b;
//from web
try {
Bitmap bitmap=null;
InputStream is=new URL(url).openStream();
OutputStream os = new FileOutputStream(f);
copyStream(is, os);
os.close();
bitmap = decodeFile(f);
return bitmap;
} catch (Exception ex){
ex.printStackTrace();
return null;
//decodes image and scales it to reduce memory consumption
* Decode file.
* @param f the f
private Bitmap decodeFile(File f){
try {
//decode image size
BitmapFactory.Options o = new BitmapFactory.Options();
o.inJustDecodeBounds = true;
BitmapFactory.decodeStream(new FileInputStream(f),null,o);
//Find the correct scale value. It should be the power of 2.
final int REQUIRED_SIZE=70;
int width_tmp=o.outWidth, height_tmp=o.outHeight;
int scale=1;
while(true){
if(width_tmp/2<REQUIRED_SIZE || height_tmp/2<REQUIRED_SIZE)
break;
width_tmp/=2;
height_tmp/=2;
scale++;
//decode with inSampleSize
BitmapFactory.Options o2 = new BitmapFactory.Options();
o2.inSampleSize=scale;
return BitmapFactory.decodeStream(new FileInputStream(f), null, o2);
} catch (FileNotFoundException e) {}
return null;
//Task for the queue
* The Class PhotoToLoad.
private class PhotoToLoad
/** The url. */
public String url;
/** The image view. */
public ImageView imageView;
* Instantiates a new photo to load.
* @param u the u
* @param i the i
public PhotoToLoad(String u, ImageView i){
url=u;
imageView=i;
/** The photos queue. */
PhotosQueue photosQueue=new PhotosQueue();
* Stop thread.
public void stopThread()
photoLoaderThread.interrupt();
//stores list of photos to download
* The Class PhotosQueue.
class PhotosQueue
/** The photos to load. */
private Stack<PhotoToLoad> photosToLoad=new Stack<PhotoToLoad>();
//removes all instances of this ImageView
* Clean.
* @param image the image
public void Clean(ImageView image)
for(int j=0 ;j<photosToLoad.size();){
if(photosToLoad.get(j).imageView==image)
photosToLoad.remove(j);
else
++j;
* The Class PhotosLoader.
class PhotosLoader extends Thread {
/* (non-Javadoc)
* @see java.lang.Thread#run()
public void run() {
try {
while(true)
//thread waits until there are any images to load in the queue
if(photosQueue.photosToLoad.size()==0)
photosQueue.photosToLoad.wait();
if(photosQueue.photosToLoad.size()!=0)
PhotoToLoad photoToLoad;
photoToLoad=photosQueue.photosToLoad.pop();
Bitmap bmp=getBitmap(photoToLoad.url);
cache.put(photoToLoad.url, bmp);
if(((String)photoToLoad.imageView.getTag()).equals(photoToLoad.url)){
BitmapDisplayer bd=new BitmapDisplayer(bmp, photoToLoad.imageView);
Activity a=(Activity)photoToLoad.imageView.getContext();
a.runOnUiThread(bd);
if(Thread.interrupted())
break;
} catch (InterruptedException e) {
//allow thread to exit
/** The photo loader thread. */
PhotosLoader photoLoaderThread=new PhotosLoader();
//Used to display bitmap in the UI thread
* The Class BitmapDisplayer.
class BitmapDisplayer implements Runnable
/** The bitmap. */
Bitmap bitmap;
* Instantiates a new bitmap displayer.
* @param b the b
* @param i the i
public BitmapDisplayer(Bitmap b, ImageView i){bitmap=b;imageView=i;}
/* (non-Javadoc)
* @see java.lang.Runnable#run()
public void run()
if(bitmap!=null)
imageView.setImageBitmap(bitmap);
else
* Clear cache.
public void clearCache() {
//clear memory cache
cache.clear();
//clear SD cache
File[] files=cacheDir.listFiles();
for(File f:files)
f.delete();
public static void copyStream(InputStream is, OutputStream os) {
final int buffer_size=1024;
try
byte[] bytes=new byte[buffer_size];
for(;;)
int count=is.read(bytes, 0, buffer_size);
if(count==-1)
break;
os.write(bytes, 0, count);
catch(Exception ex){}
thanks for helping
