Help problem with motorola motoluxe
teethman
Hi I bought a Motorola motoluxe few days ago and I have problem with it. Its always jammed when I keep it on charger at night and when I try to restart it by removing the battery ( which is the only way to restart it) it keeps showing the Motorola logo without any change for over 30 min.
I googled about how to fix it and the only thing I found is to factory reset. And I did that. Its start normal then when I downloaded programs from play store ( opera mini, viber, Skype, multiling keyboard, tumblr) and try again to restart it as a test it jammed again. Which make me to do a factory reset again to make it work.
Please what's the problem with it? How can you help me with that?
Regards
Hey teethman, Welcome to AF! This thread would be better located in a device forum. If you approve, I can move it there for you. :)
I grabbed this for Anti, as he must be away at the moment. I notice it is a little quiet in this forum, so if you don't get any responses to this or your other thread, we'll try something else.
