Help Problem with my Galaxy S3
nicknab
Hey guys, hopefully someone here can tell me what is wrong with my phone
Basically i cannot make any calls or texts with my phone, when i try to make a call it comes up "not registered on network" this only started happening yday
I can use the internet, maps etc without wifi so it is just a calling/texting problem i have
Also my sim works in my brothers iphone 4 so no problem with the sim
I contacted o2 who have said that there is no problem at their end, my account is not barred, the IMEI of the galaxy is fine, so there are no restrictions
I have done a full reboot of the phone and also made sure airplane mode isnt on
I just dont know what is wrong with my Galaxy S3
Any ideas???
Try doing a factory reset with the SIM inside the phone. This will reset the phone to factory settings and may get the phone to work with the SIM.
Done this at least 5 times, and it doesnt work! When i try and make a call its the same thing
So frustrating
Try going to Settings - Wireless and Networks - Mobile Networks - Network operators and then either Search Networks to select the carrier you are with or Select automatically to see if that makes a difference.
Also make sure the Network mode is also on auto (or GSM/WCDMA)
If there's a warranty go to service center. I read some discussion on other sites, I don't if this is a bug, but they have some problems as yours. There's an instance it was replaced by new one and still with same problem.
I have heard of some Sims having errors in only certain phones.
I think swapping the simple ix worth a try. I iv it ix unlocked, and you can also try someone else's sim card.
I have experienced some of the same problems you have... I am now reverting back to iPhone.. after trying two different s3's
Steinar
I have samsung galaxy s3, if my mobile remains idle for few hours, and after i try to call someone, it shows an error saying "Not registered on mobile network". And when i I restart my cell, its start working. and same thing happens after few hours. I have done Factory data reset twice but still the problem persists. How to solve it?
Hi,
Is your above mentioned issue solved ? I am facing exactly the same issue on galaxy grand GT-I9082. Please if you can help!
