Problem with my icons
I have a problem when my Nexus 5 has no more battery or when I switch it of, all the icons on my "second screen" are erased.. So I have to re-organize my screen .. I don't understand why it disappears.. And sometimes the icons of my apps come back as before. I would like to understand what is going on because I'm fed up to put all my icons in their place!
thanks for your help!
That's weird, it shouldn't happen. I know it's a pain but you should try a factory reset. If the problem still persists, then I'd give Google a ring and try and sort out a replacement.
Have you tried going to Settings > Apps and clearing off the data for Google Now Launcher? That might help. Otherwise a factory reset will probably solve the problem.
