Help Problem with Nexus S updating apps...
limedelta
Hello I hope someone can help me.
I have a Nexus S and when i updated to ics i cant update my existing apps in the play store it says error code 921.
I've spoke with google and we've tried loads of things but they now want me to factory reset and im not going to do that.
Has anyone got any ideas what's wrong ?
Thank you
Thank you
Two things you can try:
1: Remove the Google account your using (Settings>Accounts and sync, Select your account, Menu>Remove account) and then redo the account.
2: Clear some cache data. Go to Settings>Applications, select Google Play Store, clear data and cache. Do the same for Google Services Framework. Then reboot.
