Help Problem with notification bar i cant use it
larrymtz
Hi if someone can help me, I'm having problems with the notification bar, when u try to swipe it down nothings happen so I'm not available to see messages or any notification, or if u try to open things you downloaded , the bar is there but useless :/ I tried doing the reset factory deleting everything except music and photos but was the same thing.
I will appreciate if someone can help me
I was thinking do another factory reset. Then do not add any apps including not adding a launcher. How does it function with no apps reinstalled after the second reset try?
To stop the apps from reloading, Go to your account settimgs in "The Market" or Google Play and uncheck "auto update" and any auto sync settings. It should stop apps from auto installing. If it doesnt help afteward. You might need to reinstall your O/S but thats drastic measures.
Are you able to talk your carrier into swapping out your device especially if you had it for a very short period?
I cant think of anything that affects the navigation bar but some apps that push ads to your navigation.
