Problem with "Oldtimer"
PLEASE☺, can ANYONE help me? 😞😞😞 I have (like 'other', BUT nice and dear!) old Galaxy S5 Mini... Phone is 'o.k.', but i made problem to myself..🙈🙄🙄🙄 I look those 'pretty' Apps in Play Store what have 'codes' for EWERYTHING...🙄🙄🙄 And, i write SOME of those codes... And i lost Signal and NETWORK at ALL, phone is like don't have Sim Card AT ALL, i don' have signal and Net, i can ONLY get by Wifi to Net...🙈🙄🙄🙄 Have SOME 'MASTER CODE', or i must do something else now?😞🤔🤔🤔 Thank you all VERY MUCH... 👍☺☺☺☺
not sure what you mean by codes. and i'm guessing that you download something from the playstore that asks for codes. and now your phone does not have signal, sim is not working, and you do not have internet. does that sound correct? not sure what phone you have but see if you can get into safe mode. most phones should have this feature. safe mode disables any 3rd party apps from running. this is a troubleshooting tool to see if an app is causing any issues. if you are having the same problem then it is not any apps that is causing this.
either way i would recommend doing a factory reset....and hope that helps.
Thanks☺, i will try, but i am not sure for that... I even do 'soft reset'🙄, and nothing...😞😞😞 It is OLD, but dear😊 GalaxyS5 Mini... 👍😎😎😎 HOVEWER, thank you, i will try, IF nothing, KNOWS😅 where his Usb go next time..👍☺☺☺ Bye!😎😎😎
It's quite difficult to read your post, it's all full of "77;☺☺☺&#9"
