Apps Problem with rendering of background
Riser101
Hello guys,
The background (example:Splash screen) that i have developed for my app is being rendered very badly on some android devices.By bad i mean the actual composition of brightness,contrast, sharpness all is getting very messed up, resulting in a very different background colour than the one i orignially created.Is there a solution for it,appreciate your help in advance! If any more info is required please ask..
Save your background image in different resolutions in the different drawable-*dpi folders. That will make your app serve different sized images for different screen resolutions/DPI's. The same thing usually goes for icons and other imagery to get the best UI experience.
For icons you can use:
Android Asset Studio
For your background image you should experiment until you find the optimal size for each drawable-*dpi folder.
Good luck!
