Campah
Member
I'm pretty sure I caused this. I wasn't thinking and unplugged my Droid when I had it mounted on my Mac. After that, I get a notification that it's checking the SD card for errors, which lasts over 5 minutes or so, then the phone reboots, and only gives me the red droid eye. The only way to get out of it from that state is to do a battery pull, but unless I remove the SD card, it will just keep doing the same thing.
Any ideas, or should I just go out and buy a micro SD card reader and format the thing?
