Help Problem with wifi repeater
Marios Georgiou
Hello,
I bought a WIFI Repeater Gembird WNP-RP-002 and i connected it to a CYTA network before and now i want to
connect it to other wifi network in some other place but when i press the wifi network ssid of repeater does not
connect and so can't configure repeater with a new wifi network. Is it something had to do with the old wifi CYTA
network saved inside repeater? How i erased this and what should if something else causing
it? I'm using an android phone for configuration.
I'm completely clueless with anything like this but as a total guess, but is there like a recessed hole I'm the back repeater or cyta (whatever that is) that you can stick a pen in to reset them?
I didn't knew about this but the Reset tiny button worked when keypressed for a while.
