Hello everyone, I have a problem with the WiFi connection, after a short use WiFi Internet connection,Tattoo show me "network error has occure.Retry,or cancel and return to the previous screen".
Hi ... I know many people having problems with the wifi... And for me having tried almost everything even bought a new router (now tried 3 different routers ).. I ended up just accepting tattoo cannot connect with wifi.. so I cannot recoment buying a tattoo.. It
I had some problems with wifi initially too. Signal showed excellent but then would suddenly disappear. I stood my router on it's side (trying to solve a different issue) and since then I've had no problems with the wifi.
The Tattoo seems to be over sensitive to signal fluctuations perhaps. Try repositioning your access point a bit.....might work like mine did....
I think I discovered the problem, the biggest problem was the bad router that I received from the operator, because when I try the other Wifi routers I have no problems with connection. I do not know what the problem is with my router.
I have a connection problem after switching to a Netgear router - now it detects the signal and sais connected but I cant actually browse or anything then it just drops the connection. Any ideas. I previously had a Linksys router and everything worked fine. It cant be a signal strength as the router is on my desk next to the phone.
