Problem: x-axis is inverted
Hello, I'm new to this forum and also new to Android.
At the moment I'm trying to tweak an Android device.
The problem is that the x-axis is inverted:mad:, but the y-axis isn't. So when I want to select something top left, I need to press top right. The touchscreen is working correctly when connecting on my windows desktop.
Maybe there is a problem in the Android source code or just a reinstall of Android on the hardware device. But how can I reinstall android(for example android 2.2)?:confused: I'm using Ubuntu 11.10, Android SDK, Eclipse + ADT Plugin. I can install apps on the device with adb.
PS: English is not my native language, so there will be some grammar errors probably.
Try recalibrating your phone, if that doesn't work try factory reseting your phone.
If either of those two do not work, try and take it back to your provider and get it replaced.
Hope i helped it. :D
