There are links here to help you install CWM recovery. All you need to be able to do is get to FTM Mode (Vol.Down+Power). Then you can ADB reboot bootloader, then use fastboot to boot the CWM image. From there you should be able to sideload my OA-SSH installer. From within my installer you can choose "Return to Stock -> Advanced Return to Stock". Then choose "Flash Stock ROM" and "Flash stock Kernel", but leave "Flash stock recovery" unchecked. That will flash the stock system image and stock kernel -- hopefully restoring your phone.
