Is there maybe a way to remove the update?
Usually not. If you just upgraded from ICS to jb then I would recommend a factory data reset. It stinks to have to reset up your phone but all the little issues you get when upgrading should disappear.
I did a software update on my phone and after it was done when I plug my phone into the computer. It does not recognize it. It wont charge or see it as a drive to transfer files. Has anyone had this issue and if there is a fix? Thanks.
I had the same problem with my wife's Photon Q...
