Help Problems after updating to 2.2
sup3r1or
Greetings,
I recently got Galaxy S from my friend, almost brand new. I used it for a few days on 2.1 and I loved how fast it was. A bit later I updated to 2.2 using Kies but then I ended up with these problems:
1. It started to lag, really moving through the menus causes hiccups and lags, loading or navigating through apps also produces the same results. Returning to the home screen can take a while.
2. Apps crash, and a lot of them do! I understand when 3rd party apps crash like facebook, but android core and core apps force quit often. I can press contacts and phone vibrates and then says it force quits.
3. My micro SD died!!! While I was moving app to sd it just stopped working. Now even my pc does not see my micro sd with adapter.
Is there any way to fix it, I tried reset to factory settings but it didnt really solve all the issues? Any help would be appreciated.
P.S warranty is still on
Do a clean factory reset after the 2.2 update thru Kies.. Mine improved after the reset.. Though Facebook and email, are still laggy, but the rest are perfect.. Hard reset thru dialpad - *2767*3855#.
