I have a bunch of the little "stubby" chargers that go into a 12V car outlet and provide one or two USB charger outlets. They look like this:
I've been noticing a problem. When I plug in through these adapters, often the device says it's connected and charging, but the battery state of charge doesn't actually go up. In fact it often continues to discharge as I use the device.
At first I just thought I had a bad cord or a bad adapter, but now it seems this is happening with a bunch of them.
Am I the only person that experiences this? Did I just make a mistake buying cheapo adapters on ebay? Are these adapters limited in the amperage they can deliver? I'm thinking when they get connected, the device senses voltage and says it's charging but there's not enough amperage to actually provide a charge. Also, the ones that have two USB outlets in a single adapter... are they more problematic because they have less amperage in each outlet?
I have found the problem with a variety of devices... my LG Optimus V, my kids' Galaxy Tabs, and my friend's Iphone. Just basically very inconsistent reliablity with these adapters and the main symptom is it says it's connected and charging, but the device actually continues to discharge.
Any help would be appreciated. I could tear my hair out testing every one of these I have but it would help to know if others have similar experiences and what could be the cause.
thanks
gary in vermont
thanks
gary in vermont
