jake_harv88
Hey guys so I had an issue flashing the newest version of the leedroid ROM. To start my phone was running stock un-rooted Android 2.1. This is what I've done
1) Rooted the device using the Unrevoked method. Everything with this went fine. I get the Superuser app and I can get the '#' prompt at a terminal.
2) Then I partitioned my SD card using Rom Manager in preparation for A2SD+
3) Then I booted into clockwork mod recovery and wiped data/factory reset, wiped cache, and wiped dalvik cache
4) Then I tried to flash the leedroid rom from zip on the sd card
After reboot my phone appears to be stuck on the HTC screen and will not move forward. But if I take out the battery I can boot back into recovery mode. So it appears my phone is not broken, but it clearly isn't working. I've tried flashing a number of different ROMs but get the same result each time. Any suggestions?
