I recently unlocked, rooted my HTC Rezound, and flashed CONFROMv6 successfully.
Then I tried to flash Nils' Business ICS 4.0.3 Sense 3.6 and my device hung at the 4G LTE screen for over 90 minutes
After removing the battery, I am able to get to hboot.
From hboot I get the following (briefly) before it gets to the hboot menu
SD Checking...
Loading PH98DIAG.zip
No Image
Loading PH98DIAG.nbh
No Image or Wrong Image
Loading PH98IMG.zip
No Image
Loading PH98IMG.tar
No Image
Loading PH98IMG.aces
No Image
Loading PH98IMG.enc
No Image
From hboot I have the following options
Fastboot
Recovery
Factory Reset
Clear Storage
Simlock
Image CRC
This is the process I followed
downloaded Business ICS and the boot image was inside a PH98IMG that was inside a folder called "kernel". (I mistakenly
did not unzip the folders when putting on my SD card)
moved boot image into the same folder as adb/fastboot. put recovery (recovery-ra-vigor-3.16-gnm.img) image into this folder as well.
usb debugging is enabled and plugged in phone,opened cmd window an cd /mini-adb
type "adb devices"
got serial # back
typed "adb reboot bootloader"
typed "fastboot boot recovery-ra-vigor-3.16-gnm.img"
I got the white htc screen,followed by recoverys main menu
made a backup
wiped and flashed rom with the onscreen menus on phone. (wiped data/factory reset, data, cache,and dalvik cache)
typed "adb devices"
typed "fastboot flash boot boot.img"
receieved the "ok" that the kernel had flashed
typed "fastboot reboot"
This is what I am running
HTC Rezound
Unlocked
Rooted
S-On
HTC Sense version: 3.6
Sofware # 3.14.605.13.171ORD
Android version: 4.0.3
Linux version 3.0.16-gd0049f1 (htc-kernel@u18000-build-144) (gcc version 4.4.3 (
GCC) ) #1 SMP PREEMPT
I have an SD card reader
The PC does not detect the phone.
I have tried the factory reset option from hboot and it just hangs at the white htc screen.
Same when I select recovery, just goes to the white htc screen and hangs.
The phone doesn't seem to take a charge now, orange light is appearing and it won't turn on.
Is there anything I can do to get my phone working? I don't care if I have to wipe it clean and return to stock rom, anything
so that my phone is more useful than a paperweight.
Thanks!
SD Checking...
No Image
Loading PH98IMG.zip
No Image
Loading PH98IMG.tar
No Image
No Image
Loading PH98IMG.enc
No Image
Fastboot
Recovery
Factory Reset
Clear Storage
Simlock
Image CRC
type "adb devices"
got serial # back
made a backup
typed "adb devices"
HTC Rezound
Unlocked
Rooted
S-On
Thanks!
