Hi there,
I was trying to develop a simple plugin for a Unity app to get shared preferences (they are stored in a slightly different location than Unity stores them). The problem I'm encountering is that the context is null.
I've tried a lot of methods to get context but it always ends up with some sort of null:
AndroidJavaException: java.lang.NullPointerException: Attempt to invoke virtual method 'android.content.Context android.content.Context.getApplicationContext()' on a null object reference
This is the plugin I've written currently. One thing I noticed (when I put Log.e in) is that it doesn't seem to call onCreate. Is that a problem?
Any help solving this problem is greatly appreciated. I've done a lot of googling but I must be missing something.
Java:
package com.test;
import android.app.Activity;
import android.os.Bundle;
import android.content.Context;
import android.content.SharedPreferences;
// This Util is used to help transition from the Android SDK to the Unity SDK
public class SharedPreferencesUtility extends Activity
private Context context;
private Activity activity;
private static SharedPreferencesUtility instance;
SharedPreferences sharedpreferences;
private static final String TAG = "USERID_UTIL";
public static final String PREFS_NAME = "user_saved_prefs";
@Override
public void onCreate(Bundle savedInstance) {
super.onCreate(savedInstance);
activity = this;
context = this.getApplicationContext();
public SharedPreferencesUtility() {
this.instance = this;
public static SharedPreferencesUtility instance() {
if(instance == null) {
instance = new SharedPreferencesUtility();
return instance;
public String getPreferenceString (String prefKey) {
//context = getApplicationContext();
//context = instance.getApplicationContext();
//context = this.getApplicationContext();
sharedpreferences = context.getSharedPreferences(PREFS_NAME, MODE_PRIVATE);
String userId = sharedpreferences.getString(prefKey, "");
return userId;
Thanks a lot!
