When I plug in the HTC Incredible, explorer shows two new empty removable drives. Neither the internal storage or the SDCard is being mounted. All the hardware is functioning correctly and both devices recognize they have been connected. The devices mounted correctly before I rooted my phone and installed the latest Virtuous ROM.
I'm able to mount my SDCard successfully when I reboot in recovery mode via ClockworkMOD. I'm also able to mount the *only* the SDCard via a paid widget app from the Market.
On the phone side, the phone is charging but won't unmount the SDCard. I never get the option to choose my connection type (i.e. - charge only or mount as disk drive).
I've tried both with and without USB Debugging. The phone tells me "USB debugging connected" when I connect the USB. I've also tried uninstalling the drivers in device manager as well as installing PDANet drivers. PDANet recognizes the phone has been connected.
Any suggestions? Everything else works correctly. I am stumped. I regularly use the Internal Storage so not being able to access it is a problem.
Thanks!
Thanks!
