Problems moving External Game a Files to SD Card
I'm currently using a Samsung Galaxy Core a Prime, and my provider is T-Mobile. I recently bought a 16 GB Sandisk microcard. And I noticed that moving a external game file Such as MC5 And CSR 2 will cause it to redo load the moved data, and I need help as this is a MAJOR problem, my phones internal storage is 3GB, please respond ASAP
- LegendOfSamsung
You probably just can't just move the game-play data files, if the games are written to only use internal. If they can't find it there, they'll re-download it into internal.
If the phone was rooted, you could probably do it with App2SD or something.
If you can move the data it will be via the game's settings. If it doesn't have a setting to specify where the data are stored then the game will have the location hard-nosed and will only look in that location.
I don't know whether adoptive storage (format sd as internal) would help with this at all, if your phone supports it (introduced with 6.0 but not all got that feature).
