Help problems please help
goku17
Member
Ok, i just bought the x10 like a month ago, i have 2 problemz tht annoying me
1, if i ad music to phone, it doesnt read it, im using media go, it read 80% of the songs i transfered into the phone
2, i just took a picture last night, this morning im try to review on it, it appears the same message. Files could not be read, and delete
3, how could i chang the startup picture in the custome folder, because mine is the picture of the phone company and i dont want it.
If anybody know or have the same problems, please post here
And btw, im using 32gb micro sd
Do i need to do anything if i buy one like that?
Thanks
ok, i just bought the x10 like a month ago, i have 2 problemz tht annoying me
**Are you saying that mediago only loads 80% of your music and freezes? If yes, than you need to check and see what song it is getting hung up on. You can tell which songs are being worked on my the indicator in the top left of the song title area (will be a check mark when done and a spinner when actively downloading).
**What did you do with the picture after taking it? Did you get a confirmation message that said, "successfully saved"? Did you actually see the picture in the camera film roll? Are you seeing the camera film roll currently? Are you looking in the right area (camera film roll), or did you relocate it after taking it? Are you using mediascape to try and locate it? If not try it, it should prove very helpful?
**Two ways to change your picture (Actually it is Wallpaper). 1st way is to use a custom THEME from a program titled "ADW", which you can get for FREE ffrom the Market. 2nd thing you can do is from your home screen, once there do the following: Press the Lower LEFT Button > Select WALLPAPER, Select Wallpaper Gallery (for the standard batch of wallpapers. Later you could choose Mediascape and use your stored photos. BUT for NOW go with my example) > Choose a Wallpaper (Once you find one you like) > Press the button on the bottom center of screen "Set Wallpaper. That Will NOT change your App drawer. In order to change the background of your App Drawer you will need a program like "ADW" (I use ADW, works like a charm) or the 2.1 OS.. Hoped this helped you out..
and btw, im using 32gb micro sd
****************Before proceeding with the recommendations that you will read here next, PLEASE ensure your info on the card are BACKEDUP, because you may be losing it all in a few sceconds! Again, BACKUP your Data!!****************
Regarding your card, have you FORMATTED it? I mean Formatted it in your Phone? If not, you may want to do that. Again from the home screen, Press the Lower LEFT Button > Select Settings > SD card & Phone Storage > Unmount SD Card > Format SD Card > Press Button "Format SD Card" > (Unlock your phone pattern if using one) > Press Button "Erase Everything". You will get a prompt read out on your "Notification Line" That your SD Card was formatted, or something similar.. Good Luck!
do i need to do anything if i buy one like that?
Thanks
welcome....
thanks for your help!
it works after i formatted the sd card and update it
also about the adw thing, i downloaded the theme from the market... then i could not find it anywhere on my phone??
and if i can find it and apply the theme to the phone...
how could i change it back to normal when i want to?
thanks again
thanks again
On your home screen, press the home button, the middle one. You should see the ADW launcher there. Tap the screen.
