Root problems rooting LG marquee
gasper6
i'm new to all the rooting process and i need someone to help me out...please
Rooting the LG Marquee
Tool Built by devecho Exploit Built by the Revolutionary Team
Rooting
Press any key to continue . . .
* daemon not running. starting it now *
* daemon started successfully *
Device found
Pushing Zergrush
1813 KB/s (22281 bytes in 0.012s)
Running Zergrush
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00015118
[*] Sending 149 zerglings ...
[*] Trying a new path ...
[-] Zerglings did not leave interesting stuff
Removing Trash and Installing Root Files
/data/local/tmp/sh: permission denied
failed to copy 'Files\su' to '/system/tmp/su': No such file or directory
failed to copy 'Files\busybox' to '/system/tmp/busybox': No such file or directo
ry
failed to copy 'Files\Superuser.apk' to '/system/tmp/Superuser.apk': No such fil
e or directory
Removing Trash
Finished Rooting!!!
I have the same issue, e.g may be it has to do with the fact that my phone after I got it from BoostMobile and activated it, it did a system update for version LG855ZV4. May be they fix the exploit.
What version is your phone one?
Srmuc69
I would bet that is exactly what it is.. If you have done the OTA Update from ZV3/ZV9 to ZV4/ZVC than the original Rooting Exploit has been blocked. You would need to try to roll back to stock via KDZ/CAB, or just wait it out to see if omeone can get another exploit going.
Yes this is what I did, rolled back to ZVC on my Boost Phone, then installed root and CWM and applied the rooted ZV4 update.
Now back in business. The guides for all this are in this forum and very helpful, read them also further down, e.g. I had an issue with the boot loop and they had under 9b as solution which worked for me.
Great work, keep it up.
Thanks
srmuc69
Thanks
srmuc69
HI, how did you back it up so that you can root your phone? If you could give some step by step instructions that would be excellent.
