Root problems rooting
jlede
Android Expert
[SOLVED]
it says adb is not recognized as a internal or external command o_O could it be cuz i set my own adb thing
edit:
[*] Connect the Dots: LG Connect Root Exploit (Windows version)
[*] by Dan Rosenberg (@djrbliss)
[*] Thanks to zandersig for testing.
[*] Before continuing, ensure USB debugging is enabled, that you
[*] have the latest LG drivers installed, and that your phone
[*] is connected via USB.
[*] IMPORTANT: Ensure your SD card is properly mounted before
[*] running this exploit.
[*] Press enter to root your phone...
Press any key to continue . . .
'adb' is not recognized as an internal or external command,
operable program or batch file.
[*] Waiting for device...
[*] Device found.
[*] Attemping persistence...
[*] Cleaning up...
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
