sith_lord85
Hi,
I am trying to create an android ocr app with tesseract and have read several tutorials on how to go about it and imported the required project files ("tess-two" and "simple android ocr"), created the ndk buld file, etc.
My problem is when i try to build/run 'simple android ocr' project I get the following errors:
1st:
The container 'Android Dependencies' references non existing library 'C:\Users\sith_lord\workspace\tess-two\bin\tess-two.jar' Simple-Android-OCR
2nd:
Project has no project.properties file! Edit the project properties to set one. tess-two
3rd:
Project 'tess-two' is missing required source folder: 'gen'
Several sites advised that i update eclipse but that has not helped at all.
1st:
2nd:
3rd:
