Root Problems with ARHD
Mehta23
Android Expert
Since my android secure errors, and having to re flash ARHD, i have had 4 white screens of sense and 5 restarts in two days. Would the priblem be rom related or kernal?
Did you super wipe?
There are no problems with ARHD. Look closer to home.
Did you super wipe?
Yes, this is really quite weird. I have ROMmed 2 DHDs with ARHD and it is super rock solid. Was there any hint of problems before you installed the ROM? Also, what technique did you use to do the
sorry for the slight thread hijack, but mines switching itself off (or screen is off and unresponsive, whichever) every time i leave it with wifi enabled. i have to take battery out each time to eset it, then knock wifi off to stop it happening again. if its not ARHD then any idea how i can resolve this problem?
thanks
Hey, Mehta23, very sorry you are having issues. You haven’t answered whether you ‘super wiped.’ If you did, did you use the technique of loading the ‘super wipe script’ from sdcard as a ‘rom loading option’ – as per the ARHD instructions?
Yeah.ended up re flashing the whole Rom and have had no issues so far
