ElJaffacakeo
Hi,
My DHD has issues - It might just be that it is getting on in life.
Sometimes when I plug it in I get the message that is using more power than can be put back into it I am am finding that I is taking 12+ hours to charge. I have the Advanced Task killer which kills apps but they always seem to reappear? Surely If I turn them off they should stay off? The screen cannot be consuming power, its only on when I am using the phone, its off all night. I cannot shut the phone down over night as I need the alarm.
Also, I am having trouble with it turning itself off and on whenever I plug it in to charge at night. It restarts (takes aaaaaages!, hangs on the HTC screen for 3+ minutes). I have since come to the conclusion that the only way to fix that is to remove the batter and charge the phone whilst its off, but that doesnt help me 'cause I need the alarm!
Anyone got any input?
Thanks.
Thanks.
