Help Problems with Galaxy Gio
faluc
I was trying to update my Gio, but I've had some problems and had to cancel the update. Now when I turn on my phone, it appears this image: (Image)
Does this have a solution? (It still can enter in download mode)
Can you still use your phone?
So I mean, does the screen disappear after while so you can still use it? If so, you could do a factory reset if the problem doesn't get solved?
Boot your phone in download mode.
Download a gio stock rom and flash it using odin.
WARNING Dragons ahead~
Make sure you follow a tutorial for the GIO on how to flash using odin.
Hit thanks if this helped you!
