Hi,
Last night I installed the latest CDMA version of GBTweaked for my locked R800x. I am running into the standard no wifi issue, however, when I tried to install the wifi modules, I found myself unable to access CWM.... I tried to reinstall CWM with no luck. Flashtool isn't helping much with restoring to a previod nandroid backup either.
Additionally, I just ran rootchecker and got this:
Congratulations! You have root access!
Superuser Application Status:
Superuser application - version 3.0.7 - is installed!
System File Properties for Root Access:
Alternative Location
Check Command: ls -l /sbin/su:
Result: exec: ls: permission denied
Analysis: Setuid attribute NOT present and root user ownership is NOT present. Root access is NOT correctly configured for this file!
Standard Location
Check Command: ls -l /system/bin/su:
Standard Location
Check Command: ls -l /system/xbin/su:
Check Command: ls -l /system/xbin/sudo:
Root User ID and Group ID Status:
Root user id:
uid=0(root)
Root group id:
gid=0(root)
System Environment PATH: /sbin /vendor/bin /system/sbin /system/bin /system/xbin
ADB Shell Default User:
ADB shell setting for standard access, stored in default.prop, is configured as: shell (non root) user - ro.secure=1
aResults provided on your R800x device by Root Checker Pro version 1.2.1 from joeykrim in the Android Market -
All my shell permissions are fubar..... I would like to find a way to fix this ASAP.. Thank you!
Standard Location
Standard Location
Root user id:
uid=0(root)
Root group id:
gid=0(root)
