Help problems with internet
I dont speak well english but try to explane what problem I have. For example if I use wi fi on my x10 all apps and internet browser and market works, but if I will use internet from my mobile network ( 3g ) works only browser, other apps like youtube, gmail, market ( all ) dont have acsses to internet. How to fix?)))
Welcome to Androidforums!
I suspect it's because the APN information is not entered.
First, try to go to Settings > Wireless & Networks > Mobile Networks > Network operators. If your operator shows up, select it and if you're lucky it will "install" the right settings at the right place.
If this doesn't work, go to Settings > Wireless & Networks > Mobile Networks > Access Point Names and create a new APN (push the menu button and select "New APN". Enter the information manually. You can search online or ask your operator for what you need to put in there.
For example this is what I have to use with Rogers in Canada:
APN: rogers-core-appl1.apn
Proxy: <not set>
Port: <not set>
Username: <not set>
Password: <not set>
Server: <not set>
MMSC: http://mms.gprs.rogers.com
MMS Proxy: 10.128.1.69
MMS Port: 80 MCC: 302 (retrieved from SIM)
MNC: 720 (retrieved from SIM).
Authentication type: <not set>
APN type: <not set>
I have one setting for MMS/SMS and data, some operators will have different settings for each, so it's possible that there is more than one.
