Apps Problems with MediaStore and GridView
Kullaberg
I'm looking for some help to solve the problem why the GridView don't show the correct number of thumbnails and instead shows a lot of duplicates of the thumbnails in groups? And when I scroll the list of thumbnails up en down and return to the top, the order of the images changes all the time.
Anyone who knows what the reason could be and how to solve it? I would really preciate some help to be able to continue my work. Thanks!
Below is the code:
public class MainActivity extends Activity {
Cursor cursor;
int indexColumn;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.activity_main);
// Array for the columns to access
String[] projection = {MediaStore.Images.Thumbnails._ID};
// Cursor object
cursor = managedQuery(MediaStore.Images.Thumbnails.EXTERNAL_CONTENT_URI, projection, null, null, MediaStore.Images.Thumbnails.IMAGE_ID);
// Number of columns
indexColumn = cursor.getColumnIndexOrThrow(MediaStore.Images.Thumbnails._ID);
GridView gridview = (GridView) findViewById(R.id.gridview);
gridview.setAdapter(new ImageAdapter(this));
gridview.setOnItemClickListener(new OnItemClickListener() {
public void onItemClick(AdapterView<?> parent, View v, int position, long id) {
Toast.makeText(MainActivity.this, "" + position, Toast.LENGTH_SHORT).show();
public void onItemClick(AdapterView parent, View v, int position, long id) {
String[] projection = {MediaStore.Images.Media.DATA};
cursor = managedQuery(MediaStore.Images.Media.EXTERNAL_CONTENT_URI, projection, null, null, null);
int columnIndex = cursor.getColumnIndexOrThrow(MediaStore.Images.Media.DATA);
cursor.moveToPosition(position);
String imagePath = cursor.getString(columnIndex);
// Sending image id to FullScreenActivity
Intent i = new Intent(getApplicationContext(), FullImageActivity.class);
i.putExtra("image", imagePath);
//Toast.makeText(MainActivity.this, "" + imagePath, Toast.LENGTH_SHORT).show();
startActivity(i);
// Nested class
public class ImageAdapter extends BaseAdapter {
private Context mContext;
// Constructor
public ImageAdapter(Context c) {
mContext = c;
public int getCount() {
return cursor.getCount();
public Object getItem(int position) {
return position;
public long getItemId(int position) {
return position;
// create a new ImageView for each item referenced by the Adapter
public View getView(int position, View convertView, ViewGroup parent) {
ImageView imageView;
if (convertView == null) { // if it's not recycled, initialize some attributes
imageView = new ImageView(mContext);
// Move cursor to current position
// Get the current value value for the requested column
int imageId = cursor.getInt(indexColumn);
// Set content of the image
imageView.setImageURI(Uri.withAppendedPath(MediaStore.Images.Thumbnails.EXTERNAL_CONTENT_URI, "" + imageId));
imageView.setLayoutParams(new GridView.LayoutParams(85, 85));
imageView.setScaleType(ImageView.ScaleType.CENTER_CROP);
imageView.setPadding(8, 8, 8, 8);
} else {
imageView = (ImageView) convertView;
//imageView.setImageResource(mThumbIds[position]);
return imageView;
