Root Problems with 'su'
i have a droid x, i rooted my phone. everything worked fine. then i got updated. phone rebooted now nothing rooted works. i try to run something rooted and it says 'su check failed' or 'barnacle requires 'su' to access hardware'. so i'm guessing its a SU problem. do i need to update the SU file. because i've tried that. maybe my superuser is bad? please help.
First time I have heard of a succesful OTA when the phone was rooted. Had you removed any of the bloatware.
Mine updated successfully and I was rooted....I had renamed bloatware,I went in and renamed it all back,removed bootstrap recovery and got the OTA to 2.2.340. Problem was once I got it,I couldnt get root back,tried for 2 days,z4root didnt work,neither did terminal emulator method...finally had to SBF the TBH 2.2.320.I was trying to avoid that in the first place...
