brtnygrn
Member
I'm not sure what the technical version name is but the new android market with books and movies I'm having a lot of problems with it and wanted to know if anyone else is having the same issues.
First of all, sometimes when I update an app(s) it doesn't go away that it has an update. And when I click on it, it just says open. It doesn't go away until I go to Settings > Applications > Manage Applications > Market, and then clear data.
Another issue is that if I uninstall an app it doesn't leave "My Apps" in the market. It is in the section of 'updates available' and when I click on it, it just says install. Again, it doesn't go away until I clear the data from Market.
Also if I search for an application, for example, "Alarm Clock", it will say '205 Apps found' but only show 10 and I'm not able to scroll down anymore. I've went to Market > settings > set level, I have it set to 'show all apps' & the little lock at the top is unlocked. So I don't know why this is happening.
Any help is appreciated. Thanks
