Problems with universal android download ?
Coldgold
I've downloaded Universal Android from a number of different sites for my orange San Francisco phone (gen1) 2.1 . When I come to install it I get the same response from Norton on my phone - "Installed package : com.corner23.android universalandroot is infected". Can any one help !?
Which are the safest download sites for this and other software for installing 2.3 custom roms on my phone.
Welcome to Android Forums -- thanks for joining the community. :ciao:
You will want to check inside the forum for your specific device model. You can choose it from the list here on the home page scroll down to where you'll find your device - and check in to your device's support area.
You can find some cool information, hints, and tips on your device and will be the best place to get device specific help.
Hopefully this place will be helpful to you.
