I'm getting really frustrated trying to watch videos on my Eris. I transfer them to the SD Card, and usually they don't work. I've tried maybe ten video files, and only three will play. I can't find the common denominator that the files that won't play have - they have different bitrates and different dimensions (both higher and lower than files that will play), and all the files were converted using the exact same settings in VisualHub (.mp4 with h.264 encoding).
Here's what I've tried:
- per another thread, I installed Cinema, hoping that some mystery codec would be installed that would allow the files to play
- I've tried playing them in Video Player as well as through Albums
- I've deleted all videos from the SD card, restarted the phone, and then re-copied them to the SD Card
- I've deleted all videos and done a battery pull, then re-copied them
- I've tried a different SD Card in the phone
Has anyone had trouble like this? Is there something I'm overlooking? What can I do - should I do a factory reset?
