V
Valiceemo
Guest
I have downloaded and installed these tasker profiles and followed all the stop instructions and it seems to be giving me some problems with my Wi-Fi.
http://forum.xda-developers.com/showthread.php?t=1031743
Following installing and activating these profiles my Wi-Fi will connect to my home network, and 2 seconds later disconnect. If I try to manually reconnect it flashes "failed to connect to network"
The only solution that works is to reboot the phone.
Secondly, the auto WiFi off will disable my Wi-Fi when my phone screen is off as this will disconnect from Wi-Fi. I assume to conserve battery. Can I prevent this?
And finally with regards to how android syncs, if my phone is off but I'm at home and so on my hope Wi-Fi, will I use my Wi-Fi to sync, even though it's `off` -or will it use mobile data?
Thanks.
LG-G2 / Android 4.2.2
Thanks.
