Help Process android.process.acore is not responding!
ivanpk
Hi,
Every so often I unlock my droid and this pops up. If I hit force close it reboots the home screen, if I hit wait it goes away and nothing seems to be wrong. What is causing this?
Could it be a widget? I use the status bar widget, facebook widget, a battery life widget, CNN widget, scoreboard widget, and a small weather widget.
Anyone else get this?
This happens to me all the time, and I also use Home++.
I think it is a Home++ thing, but if you simply hit Ignore, it is as if there is no problem
It only happens to me when there is an incoming call, the if i hit ignore the phone rings until i pull the battery, if i hit force close it just goes to the home screen. there are never any missed calls in the log, but i do get voice mails.
i am not using any cut
Several forums link the issue to bad shortcuts (typically when using Any Cut), and/or corrupt contact information ... either within a shortcut or in the Contact's information itself. You guys can take it from here ... but you might want to see if there's a certain contact or shortcut that is causing the issue.
out of all the times this has happened, 1/2 the calls i get are not saved in my contacts, 1/2 are.
it ONLY happens when I'm receiving a call.
for what its worth my droid is OC'd to 900mhz, and has been since the rom was released with no problems until i installed home++. I didnt like home++ and uninstalled it the same day.. this was at least a week ago.
for me it happens when i get a text message.... and it really interferes with them also, sending many repeats and receiving many repeats... also it will delay text messages but if i restart the phone it will send them right away
oh and not using any cut
Similar problem, but with the Calender.
"The process com.andriod.calender has stopped unexpectedly. Please try again"
I'm betting this is related to a contact issue. (don't have anycut)
