Help process com.android.settings
jsdewar
Samsung Galaxy S (US Cellular "Mesmerize") with Android 2.2 operating. When accessing "Notification Ringtones" ... receive the message, "The application Settings (process com.android.settings) has stopped unexpectedly. Please try again. {Force Close} appears.
Any one here have any idea how to fix this?
Thanks. :)
Yep....powered phone off, pulled battery out...waited a full minute.....put battery back in ..... problem remains.
Other ideas or fixes??
Did the problem start after doing the Android 2.2 upgrade...?
Just curious as I've heard people complaining of getting errors after doing the upgrade.
If it started occuring after you applied the 2.2 update, you may want to consider doing a factory reset and seeing if that clears up the problem for you.
Same problem here :-(
Which upgrade do you have? EC10 or EE19? How did you install it? At the store, or did it yourself with mini kies?
This thread was created by someone having issues with the EC10 update, most likely done via mini kies download.
There are now 2 updates available, so we really need to know more about what you're running and how you downloaded the update before we can help you.
