process com.softwinner.explore
chua
I have problem with my Andriod Table PC - File Manager ;
Can you help me to solve the problem below ?
"The application File Manager (process com.softwinner.explore)
has stopped unexpectedly."
Rgds,
Hello and welcome aboard. This error message occurs when an application has suddenly force stop. Usually this is caused by an incompatible or corrupt installed app. If the 'culprit' is found and uninstalled then the problem will be fixed.
I hope this info will prove useful to you. ;)
Welcome to the forums chua and abhilas, glad to have you here :)
I will notify you both that the thread has been moved to Android Applications maybe someone here will be able to help you with your problem :)
Thanks again for joining :D
