Help Processor speed
Carlos A
Member
The Transformer Prime has quad core Tegra 3 processor. Does anyone know what the cores are clocked to? I tried to search it but it never said the clock speed just said Nvidia Tegra 33 quad core processor
From the reviews and specs I've seen they should be clocked at 1.3GHz
But when using a single core only it appears to clock higher according to some. Allot of apps I use for benchmarking report CPU speed as 1600MHz which seems too high.
are you in performance mode? If so then 1600MHz is correct. Viperboy over on XDA has a tool called Vipercontrol that lets you set balanced and power saving mode to 1600Mhz as well.
Here is a link.
[MOD][Updated 1.12.12]viperControl v.001 for Transformer Prime - 1.5GHz&1.6GHz mode! - xda-developers
Is the performance mode on-demand upto 1600MHz or locked at 1600MHz and is this also when all 4 cores are in use?
