nymetzfan05
Hi,
I purchased Tasker awhile back and have been able to set up easy profiles but can't figure out how to set-up the home wifi profile.
I would like to disconnect 3g, enable wifi and disable pattern lock when I am home and connect to 3g, disable wifi and enable pattern lock when I leave home. I have Secure Settings installed. I have read posts in different forums but unfortunately (for newbie me!) the posts assume you know where to look for different options and I am not sure on some things. I think my biggest problem is that screen dim for a certain amount of time (how long I don't know?) needs to be added as part of the task but I don't know where that option is or where to put it. Can someone please give me a step by step on how to set this profile up? Would be much appreciated!
Thanks.
Thanks.
