Help program monitor (default) widget
gomgnut
Hi
I have reflashed to JG4 as I tried to update through kies and couldn't reboot phone. I realised that I now have a program monitor (linked with the inbuilt task manager). Unfortunately, this widget (?) was accidently deleted from the home page. Its the one where it takes up 2 shortcut spaces horizontally displaying how many apps are running. Is there a way to get it back and how do you install widgets (and default ones) again? If it can't be done without reflashing, is there a way to backup call logs and phone memory etc without using a root program like Titanium?
Thanks
gomgnut
you dont need to reflash to get the default widgets.. just keep a unused part of ur screen pressed.. then go to Samsung Widgets and select Program Monitor..
omg I am a complete noob. Didn't even know you could do that... Thanks heaps and sorry for wasting time with such an obvious question to some! :)
u mean in power control? that's the auto-sync (or maybe just sync).. u can change the settings for that in (settings >accounts and sync)
